The cfi 800cc Polaris engines need the " Fix it kit" installed for long term durability and reliability. The stock piston skirts are to short and the wrist pin location is in the wrong place. Both problems make for a bad situation over some miles and use, basically a ticking time bomb if you ask me. The Pistons slap around in the cyclinders and the excessive side force with crack the skirts at some point. Everybody I ride with has done the updates and no problems since, they will self destruct if not fixed.
Actually, IMO, the cylinder skirts are what is too short. Thats the design flaw. And here is why;
Polaris makes the smallest and lightest 600 and 800 engines. This is a good thing on all accounts. Except for the cylinder skirts. In order to have the smallest and lightest engines, they had had to have the bottom 5/8" of the piston skirt to drop below the cylinder skirt. But the 2 bad things about this design is they lose case volume, which can lead to lower hp, and it obviously does in the 800, and the bottom of the piston is unsupported. Because the bottom of the piston is unsupported, it rocks ever so slightly. What happens over hundreds of thousands of piston strokes with the piston rocking even slightly? The piston collapses. The cylinder is harder than the piston. The early CFI 800s had issues with piston skirts breaking. Then in 09 or 10, poo had thicker skirts in the pistons. Then they started having cylinder skirts break. In 2013, poo put thicker cylinder skirts on the intake side, the side that always broke because thats where the force was. Since 13, the failure rate has been less.
IMO, there is no 100% fix for this engine design. Fix kit pistons with shims, Indy Dans fix, etc. To properly 100% fix this issue, the cylinder skirts must be extended. All the fix kits with shims do is lessen the rod ratio on the piston. This helps, plus it gives more case volume, but its a bandaid. A good bandaid, but still a bandaid. Same with Indy Dans. He weld braces on the cylinder skirts along with less rod ratio. Anybody have the Indy Dan complete engine? Ever open it? Of course not, because he will void your 3 year warranty if somebody other than him opens one of his engines. He claimed to use Poo OEM pistons. Well, somebody opened his engine. Guess what, he used SPI pistons in it. He got called out and made some excuses. If Im spending $3500 on a "bulletproof" engine, I sure as heck want to know whats up.
Anyway, the rod ratio in fact is as small as the AC 800 engine. Hmm, arguably the best 2 cylinder 800 ever built. So its clear, the rod ratio isn't the problem. So the wrist pin is in fact not in a bad or wrong location.
And if anything, the Polaris pistons skirts should be SHORTER. But they can't be shorter, because if the are shorter, the ports will become uncovered at TDC(top dead center). And making the piston skirts longer will make the problem even worse, and they will hit the crank and BDC(bottom dead center).
So its clear, the only proper 100% fix it a complete redesign of the engine.
Im perfectly fine replacing pistons. The RMK chassis, is IMO by far the best in the mtns.
BTW, I have 3000 miles on a 12 RMK. At 1500 miles, Wossner pistons were put in. The stock pistons were bad sloppy. At 26xx miles I opened the engine and measured the pistons and cylinders. The Wossners were .002 smaller than when installed. Thats pretty dang good. Remember, these are all mtn miles. The sled doesn't ever get ridden below 6500 ft. I have a 14-1 compression head on it as well. I can't run the engine at low elevation without race fuel or I will detonate the pistons to pieces.
So as you can see, even though I just dogged on the poo engine design, it can be made to live a happy life.
The 600 is exactly the same. Though because the mass of the pistons is less, they are less prone to breaking. What happens on the 600s is the pistons rock so bad after time that the top of the pistons start rubbing on the cylinders and they knife edge. Then what happens is you lose compression at an extremely fast rate. Thats best case scenario. Worst case is aluminum breaks.
All this is from first hand experience. This isn't something Ive read on the internet. This is from polaris engines Ive opened and "fixed" or rebuilt. All measurements that Ive seen with my own eyes.
