After this w/e of busted knuckles I now have confirmed these little pains in the butt are the item I hate the most about sledding. I had a very small tool that I have had since the days of the INDY wedgie which those springs were not very hard to reach and you could always just use a screwdriver as a "ramp" or "lever" to have the hook just slide down the screwdriver shaft. But yesterday my trusty "old" tool broke mainly due to clearance issue and I flexed it to much and worse yet I could not use the "screwdriiver lever" method as you need a lot of clearance to rotate the screwdriver (or you can say the motion is more like flipping a switch).
So what are you guys using to defeat those knuckle busting little beasts? Are there any decent tool(s) out there that work good in these ever-shrinking motor bays? Getting them off is not so bad as my trusty long hose pliers usually work (until I loose my grip and they open up which sometimes happens) it is the install that is always a problem especially when the 2nd end is also a hole.
