Thanks for the info just didn't want to order the wrong thing.
Ezra- This one really didn't break It just came unscrewed. Some loctite would take care of that... But with that said you mentioned the cost being just about as much as the whole setup. After 3 I would assume you're correct, otherwise I found them for 20 bucks for two tips. I've never ran the ice scratchers on my sled before I figured these are on there might as well give them a shot.
And honestly I thought the damn thing was on there when I bought it from the guy.My son only rode it 5 miles in the yard. Then I took it to the shop have them give it a once-over oil change chain case and all the usual prep stuff... When we got up on the trail last weekend it was dragging. As you can see they were zip tied in place. So that was a little bit of a shock but then I realized the tip was gone. So I'm not sure if it happened in the backyard or when we were on the trail somewhere either way it needs a new one.
If I end up not liking these do you have another brand you recommend. I actually thought SLP we're supposed to be good?
I agree with Old Abe, sold the first sled they were on and in second year on second sled, hands down the best. They may cost a little more but well worth the money.
<br>Agreed, works well, but makes it VERY difficult to load onto a tilt trailerAs @rp7x has stated in the past, a stud in the back corner of the ski works wonders. Rode with a guy on an older Yamaha this year, and that single stud in each ski was really throwing the snow around.
Whoa, the curved tips bend back?
Whoa, the curved tips bend back? How in the world did you accomplish that feat?
I wish there was a simple answer. I call em clangers. Those rocks that glance past the skis at speed seem to do the trick.
This one is Blizzer. I caught it early and bent the tip back a little with box wrenches along the trail.
I didn't catch this one in time, so I flipped the tip and tied it after the picture. (That was before I carried spares.)
Scratchers are a wear item IMHO, that just add to the expense of riding. I am super diligent about not using them unless needed. I lift them across pavement or anywhere they might catch. I have gotten used to looking down while riding to make sure they aren't dragging by accident.
I've experimented with various hangers and also used regular wire scratchers hanging off the rail. Wire scratchers seem to hang better with clangers because they don't stick out as much. I zip tie that style to the rail.
I tried boogie wheel hangers this season with both style scratchers. They actually work fairly well. Wire scratchers stay put for the most part. Cable scratchers broke the zip ties holding them. I switched to double looped safety wire.
I've learned a little about scratchers through the years and I keep looking for something better. The main goal is to find scratchers that do the job when needed and stay up when not needed. I'd be plenty happy going riding without looking at the skid for awhile.
