Sorry for not takin more pics, i'm almost finish and will most likely finish it up tomorrow. i got a 31cc ryobi weed-eater motor with a sprocket already welded on it and made my own motor mounts for it (took 3 hours to make them lol) and i think it will work. i have to make a stand so i can start it up and hop on it and go because i have no clutch. i got it with no airbox and muffler, so i made my own airbox (now starts on the first pull and runs a lot smoother) but i kept the muffler off. i also attached a string to use as a throttle. i have to attach another string to make it longer and put it on my handlebars tomorrow. To attach the motor to the wood i cut out a square with a reciprocating saw in a chunk of plywood and screwed it into the exhaust manifold. it's really solid, a lot more solid than i thought it would be. i still have to attach the 2x4 on top of the brown stained board to the brown stained board. i did have a metal rack on the back, i just put a chunk of plywood on the top and bottom and put a bolt thru it to attach wood to it. overall everything has been working out good so far. i originally had the motor mounted on top of the rack but now that won't work since i started it up and turned the tire backwards lol. so that's y i have the motor the direction i have it. oh yeah i might put a brake on the front tire tomorrow and i still have to put the front tire on.
