had to share a pic. It really worked slick, 2 forward facing sleds have 37” front ends. Any wider and this wouldn’t have worked. Not very difficult to load the 3rd sled either, I’m sure with track mat/grips to help it would’ve even been better!
Indy - this has me intrigued. I have the same trailer but drive on drive off. I'd consider doing this with 2-121" and 1-144", all stock front ends. It always crossed my mind to try but wasn't sure if the trailer would handle it. And I wasn't sure how to go about tying the front facing 2 down as well as the rear facing one.
if your only hauling 1 sled, I think you would be tons better off getting a single place aluminum cargo like trailer, you get the same rear drive up ramp, trailer would be a bunch narrower, lighter and easier to move and hook up
and odds are a bunch cheaper to buy!
why haul a bigger wider brick behind your vehicle when not needed!
here is a build on one to maybe give you some idea's. he went steel frame, but if keeping a long time, aluminum would be better IMO(lighter to handle as well)
but food for thought here for you
here is a link to a build on a single place trailer!
https://www.hardcoresledder.com/threads/whiteout-project.1839712/page-13#post-20529981
Trailer frame and axles were within weight rating. The oem tires were not which is why I switched them out for 10 plys. Think of it this way, 3 modern mountain sleds can’t weigh anymore than 2 yamahas LOLthe BIG issue here I see and I am NOT bashing, we have all done things to get the job done
BUT odds are this trailer axle was WAY past its rating,(possibly tires as well here)
and could have ended up with a dead trailer along the roadside ending a trip and making all sorts of new problems, or worse causing an accident when/IF things fail, and open you up to a law suit for a over loaded trailer, which could be a whole different can of worms!
so just cause you can fit things IN/ON a trailer, doesn't mean one should do this!
trailer, axles and tires have weight ratings for a reason!
HAHA< soke 4 strokes are heavy that;'s no jokeTrailer frame and axles were within weight rating. The oem tires were not which is why I switched them out for 10 plys. Think of it this way, 3 modern mountain sleds can’t weigh anymore than 2 yamahas LOL
Family needed me here first and foremost and I knew I would figure out the sled to trail detail later. Later is now and have to make it easier yes more complicated than riding from home but very doable. I’m working on it!
