Ladies and Gentleman, here is my latest progress report. I did receive the airbox piece from Kelly, who was kind enough
to send it as a early christmas present. I am sure most of you would prefer some snow on the ground, so I am asking
for that wonderful white stuff for all of us.
I finally got the seat mounted, again a big thanks to my upholstery guy. It was worth more that the $65 labor he charged me.
I also replaced the coil, as I mentioned in a earlier post, and made up some new plug wires. The original coil was all eroded under the cap as it had been arcing for some time. It starts and runs much better now.
the plug wires are pretty straight forward, they twist into the cap like a screw, and they do the same thing on the coil. I put the old spark plug caps on first, after I cut the wire to length. When that was done, I screwed the wires into the new coil and pushed the rubber boot in place and they are now ready for many more years of sparking..........
Just a note, you can buy new plug wire caps from your local motorcycle parts store. I actually did buy these NGK caps, but I chose not to use them, as they were to be used without the little tip threaded on the spark plug. My reasoning is not all brands of plugs have the threaded ends that you can remove. I have not checked but I am sure they make them with the larger insert to fit a normal plug. These were less than $5 each
I did get a chance to ride it around the yard when we had snow, and here it is waiting to join it big brother 1979 TXL in the trailer
It still needs some work done, but the mechanicals have been addressed for the most part and it starts and moves under it own power.
I dont know how fast these sleds are, but it should be a good performer with as light as it is. I read somewhere in the neighborhood of 400lbs.
hope everyone enjoys the updates, think snow!!!!!!
