tubbywolfe
How does one remove the exhaust springs? Is there a special tool? Can this be done with a channel lock?
Thanks
Thanks
I read a tip in one of my snowmobile mags last year. They said to take an old flat head screwdriver and use a cutting wheel or dremel to cut a notch in one side of the tip, so you end up with a "hook" like end. I'm not explaining it well but hopefully you get the idea.
I like the shoe lace or bailing wire idea too.
Make a run to Harbor Freight. I still stand behind these " spring things " love them. $6.99 for all 3 , if I remember correctly. If you start modifying a flatblade screwdriver ( good 1 ) grind & quench in water several times during the process. That way as you heat it up , you cool it and hopefully don't loose the temper of steel. It will hold up longer that way. Of course it has to be steel with carbon in it , not a screwdriver that gets it's hardness - toughness from some plating - coating.
