So I bought my trailer used, the guy before me was towing with a Class C RV. With that he was using a weight distribution hitch. He included that as part of the deal and I have used it anytime I'm pulling the trailer. Obviously if the trailer is light then I do not need it. I also don't use it on local driving. Also, with most weight distribution hitches they have the bars which require a wider spread to the tongue of the trailer. The system I'm running it the Anderson WD Hitch. It uses chaines and tension. It also helps with sway control and I can feel the difference on the highway.
Truck 2013 RAM 1500 5.7L Crew Cab with Airlift 1000 added to the springs and Cooper Discovery Load Rated E Tires
I should note I only put 15LBS of air in the airbags only enough to help the RAM rear coil springs. Also, I have the 8 speed trany with the 3.20 rear end. (Yeah I know, I had a lot of back and fourth when ordering the truck and had a different rear end ordered but RAM changed the order on me and did not tell me. I found a sticker on the rear end a week later. Complained to the dealer and they said It was an issue with the build combinations I picked. At that time you could not get the 8 speed with the rear end I wanted. They knew I wanted the 8 speed trany.)
Trailer 2014 RnR PSD7.522 (7.5'W x 22' box+ 5' V) Total is 29' ish feet ball to tail. Empty it weights 3000#
Here is the link:
Our sturdy weight distribution hitch or sway control hitch reduces any unwanted movement. It's rated up to 16,000 lbs and is available in different sizes.
andersenhitches.com
For the most part I'm happy but a bigger truck for towing is always better. but being my daily driver too, it's give and take on some things.
(Wish I could say it always looks this nice but I just repainted it and put new chains on)
