Well I got most of the parts today, everything but the jug. I tore carbs apart and cleaned in prep for when the jug comes. The only things I found so far were a "starting" jet that looked somewhat clogged (bad side) and the idle mixture screw on the bad cylinder was out 2 turns while the one on the good cylinder was out 3.5 turns. The air box rubber inserts seem to be nice and snug on the carb intake horns, and no water in tank or carbs. Carb boots to cylinders were in place and tight. The more I dig into it the air in the oil line to the crank seal just keeps haunting me! No air in the other three lines, just the one to the crank seal on the bad cylinder side. Could a bad crank seal suck air around the seal as well as suck air bubbles in the oil line???
MORE QUESTIONS:
If it is a crank seal, can the case be split and seal replaced without tearing the top end all back apart?? Or, am I doing all of this work just to do it again?? I'm thinking if it's crank seal I may want to have someone do it for me so they can check all the stuff you're supposed to check when it's apart.
Does anyone have torque specs for cylinder and head as well as tightening sequence?? 2005 RMK 700.
There are no seals shown in parts breakdown for the head bolts but there looks to be some sealant stuck under the heads. Is there something I should apply to bottom of head of the head bolts when reassembling?
Last one, when moving to the garage I got about a thimble full of antifreeze in the crankcase. I sucked it out with an extractor but can't be 100% sure that none got into the other side of the crankcase. What's a trick to making sure no water left in crankcase? I was thinking of leaning sled on side (toward bad side) and water/oil should run to bad side where I can check it or get it out, right??
Thanks for all your help!!!
