Ok, here's the scenario. About 400 miles ago (in December) compression was 125 on both sides. Yesterday went out for a ride after fueling up and about 10 miles in I gave it the beans and the temp light (det) flashed and it died. Could not pull engine over. Removed plugs and engine turned fine. Put new plugs back in and barely starts, wont idle at all and runs like total crap at half throttle like its not really even running on one cylinder. Rev it up enough and you can get it on a trailer (barely). Got it home and left plug was black and "normal" looking. Right plug was clean as a whistle but slightly wet. Odd thing is the right plug and cylinder don't really smell like gas. I thought aha! water in fuel but lets do a compression check before we start working water out if system. Right cylinder is still 125 but left is only 45.
My question is this: Is this normal for an engine failure? Could water in the fuel cause this engine failure? I did not check for water after the bad news, just shut the hood and logged on to jd.
