you guys are bringing up good points for the fuel system but here is where the problem is. Anytime a engine sits is it subject to condensation sitting inside the engine. Imagine a spec of corrosion on a main bearing and than asking it to spin at 8000 rps. How many years do you expect it to last? Imagine putting your seasonal engine in storage with a coating of oil on the interior of itself. It can prevent the condensation from doing it's thing on metal. Today's oils are better that years ago and do help. Have you even went into your tool box at the end of winter and find your tools cold and wet. Or do you have a diesel and the water in fuel light come on. Temps and humidity contribute to favorable buildup of condensation. The last place you want moisture to sit is inside your motor for months. Treating your fuel and running your motor is a definite plus in keeping corrosion at a minimal buildup between intervals. Most people are not going to run their engines monthly and allow them to warm up fully. We say we will but before you know it 3 months have gone by and the gas is going bad. Fogging a motor will give you piece of mind that the interior of your motor is coated, that is if you follow directions. Many of us keep getting different sleds etc,,,, before enough damage occurs and performance slips or damage is done.
MY dad had (2) Hahn Eclipse mowers from 1957, gave both to me. The one he ran he always removed the plug and poured oil down the cylinder and I used that mower till I sold it. The other mower engine locked up 20 years ago from rings seized to cylinder, main bearing was surprisingly smooth.
Bottom line, keep metal oiled or keep it moving. I personally find it easier to fog and forget than run it often, although I have done both.
Puttin oil down the cylinder will eventually get in the case and leave the cylinder dry, take a piece of metal and tilt at at an angle. pour oil on it, there's hardly an oil film after a week.
I fog anything 2-stroke (weed eater, sleds, etc.) 4-strokes, just put 2 ounces a stabil in the gas tank, run it for a bit, and the next season, I don't start it till I change the oil, .
Then why do you go through the trouble on your two strokes? They're the same as four strokes. Same pistons, rings, bearings etc. Oil doesn't know if it's a 2 or 4 stroke. Runs off the same. Useless hassle. Might as well just turn them off until next time.
btw, if you don't change the blower oil in the spring, there's 100% chance that your cast iron crank case is rusty on the bottom by fall. The water settles to the bottom, and yes you do have water in your oil(condensation), and rust begins.
But, like you said, just an opinion.
Indy, in all your wisdom, did you know that cylinders are made of steel? Did you know steel rusts? Thats why you fog a 4-stroke. I have a race car engine that has some higher end parts in it, sitting in the corner of the garage without heads on it in a bag. The cylinders were sprayed down with fogging oil 3 years ago. Guess what? No rust. A slight film is all it takes to protect.
BTW, if your crank is bathed in oil, you have way to much oil in your engine. Cranks sit above the oil level.
Pistons dont rust, they are aluminum. They can corrode though, but your cylinder walls will be garbage before that happens.
Same with your bearing-less engines
it doesnt matter 2 /4 stroke or steel /alum .if you coat it with oil it will help protect it .why not its easy,cheap and doesnt hurt anything .everything i start up after storage smokes like crazy. so all the oil didnt leave .i have had good luck with it .
Now the exception is the old lawn mower that won't die. I would like to get a new one so I don't do a darn thing to it. Of course it starts on the first pull every time just to spite me!
