Team Two Stroke Smoke's recent project
snopro1000
We have been working on building a new sled trailer. It turned out so good I had to share it!
snopro1000
Not as dry as they would in an enclosed.... But it’s hard to find an enclosed that hauls eleven sleds. We are going to find out soon. Heading up your way Tuesday if this storm pans out.
L
lenny
it will pull real good, nice not to have a sail behind you yankin you around and costin you MPG's
cuzzinolaf
Is it double stacked all the way back and you just don't have the other sleds/section on?
snopro1000
hauled it through a scale yet?
where is 11 in the bed ?
No need to go scale it...... the motor home is rated to tow 20,000 lbs. We are not even close to that.
There is room for seven on the bottom if you put one on backwards and we can get four on the top deck.
Rotax1
There is no way that coach can pull 20000 pounds safely. I would check the specs on the rear diff, trans, hitch. I have a 45' Prevost with a 600 horse cummins that is only rated to tow 15000. That prevost also weighs in at 45000. Be careful i think most sportscoach coaches are rated at 5000 or 10000.
snopro1000
There is no way that coach can pull 20000 pounds safely. I would check the specs on the rear diff, trans, hitch. I have a 45' Prevost with a 600 horse cummins that is only rated to tow 150000. That prevost also weighs in at 45000. Be careful i think most sportscoach coaches are rated at 5000 or 10000.
Thats fine there is no way the trailer flully loaded weights anywhere close to 20k. Its in the 10 to 15k range tops. I've towed 15k from Phoenix to IA with no problems.
frosty
Heres a question, what is the Motor home plated for? With that kind of weight, you get pulled over and your over weight for the plate, there going to be a hefty fine and your not moving until the plates weight is met. Also, do you have a class A CDL? Again, if don't have the license to pull that weight, that's another fine!
