Mountain sled doesn't need anything? Hmmm, that's because you need to ride it more, cough cough...domesticated Indy...cough.![]()
Just avoided trees every ride last year for a change!
I originally used synthetic. Then I switched to 80w90 gear lube. Still leaked so I plastered RTV all around the chain case seal and put gear lube back in and it held for the year. Bits and pieces of the RTV mixes in with the oil so obviously looking for a permanent fix now.Indy. Are you using synthetic chain case lube in that 2000? You may want to try a conventional lube. The synthetic lube can leak through older style seals.
