famousguy you would have to look up each OEM 120 to 140hp 2s engine sleds & then compare 120hp to 140 hp 4s sleds. Not many new 120hp 4s since they produce 125-139 hp when dynoed. 2s 120hp could be 118hp just real world of hp 2s & 4s & power bands very different as well.
The weight issue is becoming a non issue because new 4s sleds are so well balanced. Back in 90s trail sled weight was a HUGE issue.... throwing my 98 Mach around took a lot of effort.
Throwing around my 600 lb 150hp 4s Attack on trail is not an issue off trail.. Yes.
The 2s vs 4s weight is not a trail handling issue & that is why 4s trail sleds are becoming soooo popular...good gas milage, broad power band,no oil smell, gas & go sleds like cars.
You need to test ride a 4s so you can see why they are becoming so popular.
If you want the lightest 4s sleds check out doo lots of 4s models.
AC,Poo & Yam heavier 4s sleds but handle very well.
I hope this helps but ride a 4s first then ask yourself if weight matters on trail. It is a non issue to me 07 Attack GT best sled I have owned & I used to be a 2s doo rider
