What happened to winter....ANSWER
Tracker
I will try to make the short and to the point but it is complicated...the earth is off by 2 months so the season is if its December 4th and winter is just starting....it will come and last longer ...my guess is until may...here's why...and here's links to double check my info...I know this because I am involved in aerospace and such and make many of the space probes so I am not just shooting from the hip of unknown....recently because the earth's magnetic sphere rotates all GPS systems were so far off the entire system had to be reset...here's the link
How the Shutdown Impacts Necessary Navigation Changes From the North Magnetic Pole’s Massive Shift – Fortune
https://fortune.com/2019/01/11/earth-magnetic-north-pole-shifts-forcing-update/
The reason is the magnetic north pole for 200 years or more has remained in a central area...imo for 10,000 years in that area...suddenly it has shifted 200 miles in a straight line as the magnetosphere has rotated and the equator has moved north 350 miles due to this shift as has the snow line...soon north pole will be the equator and equator will be the poles...to check me on this here is a film showing it....watch it all but magnetic shift starts at 330 roughly
https://youtu.be/g26pW-oIE9c
The proof of all this happening is called the geomagnetic reversal and it happens like clock work....the world is warming but it's not man made and we are not causing it and can never change it no matter what you hear....it has been confirmed in the mountains layers of rock that the lava has dried pointed north and south over 1 billion years...you can double check me here
https://en.m.wikipedia.org/wiki/Geomagnetic_reversal
Well I hope this enlighten you all and if I can teach you something then it was worth it all...remember no political theory or man or news story can over ride these facts...so be knowledgeable and in the CORRECT know and enjoy sledding longer....the water will come and to survive you need to be more than 300 feet above sea level....when exactly this happens could be 1 year or 100 years...it happens every 780,000 years and we are at 779,999....it is what it is...I hope I shed light on this subject....bash away if you will...carry on...see you later...much
Ps...I have a broken neck and a fused spine and have 500 miles in so far you wimps...I tried jumping a river at 70...didn't make it...but got back on...tracker over and out
united
Undoubtedly shifting of the poles contributes greatly to the ever changing cycles of the earth. Welcome back Samsquatch.
Good to hear from you Tracker! I see this was your first post. LOL ;)
slimcake
How ya feeling with them broken parts Tracker?? Good to have you back! I will research your links tonight. Should make for an interesting evening!
WorkHardPlayHrd
Welcome BACK!!!! Hope you are feeling better. Thank-you again for help with daughter's sled again. It's purring like a kitten!
P.S. my day in this barn has sucked so far, and pulling up this post has just put a smile on my face.😀
DamageInc
Yes, the magnetic poles are shifting, but they have little to do with our temperatures. For our seasons to be "off by two months", the earth would have to have shifted radically on it's axis, which would change the time of dusk and dawn by a very noticeable amount. Our seasons are controlled by the amount of daylight, and shifting magnetic poles does not change the amount of daylight. You're confused.
You didn't enlighten anyone. You pushed a ridiculous conspiracy theory which is very comparable to flat earthers.
Glad to hear from you again. I guess you are proof that "Cat's" do have nine lives. That still does not prove diddley about Sasquatch though! :suspicion: LOL! Take it easy.:cool: -Mezz
1fujifilm
OH, **** NO!
I MEAN OH, **** YEAH!
Bear
m8man
Moderator
I was going to research all of this but instead I'll just have a whiskey and go to the bear belly.....
m8man
