The weights should move freely by themselves. take out the weight pin with an allen wrench. Note which pins and nuts go in which holes and the direction they point and make sure to put them back in the same spot. Take them out and slide the weight back on the pin. It shouldn't be able to wobble like a wounded duck. If you can see the bushings are ovaled out, I'd replace it. Many people remove them with the slp tool or a pin punch. Personally, I'm just VERY careful and drill the bushings out. I would spend an hour removing the old bushings and drilling them out takes 5 minutes. Have to have the perfect size drill bit, a little smaller then the I.D. of the weight. 3 weights w/bushings are about $75 new i believe from Pol.Great info...thanks...here's what I see after taking apart the primary:
# 8 (the rollers) roll just fine. They are nice and smooth and when I flick them with my finger they all keep spinning for a while. Sound OK?
# 11 (1321685 WT/BUSH.ASM,10-54) are all smooth and don't have much wear. However, how easily should these things "swing out"? I can swing them all by hand fairly easily, but get this: when I hold the clutch over my head, only 1 of them freely swings down with gravity. The other two stay put. If I flick them, they move easily, but they don't just "fall" with the gravity when I hold the clutch upside down. Is that significant enough to be causing my problem?
Any other things I should check?
