Put 325 miles on my 07 attack GT LTX in the U.P. late last week. I have mine set up with the 11MM square 6" carbide on the inside and out. The skis seemed to turn more consistantly than the O.E.M. skis but I usually ride in northern Wisconsin where the turns are more icey so I won't have a true feeling for them until I ride back there next weekend.
One drawback is that my sled has developed a "darting" issue with these skis. Seems impossible with dual carbides but it was definitaly an issue. I tried backing the front springs off a few turns and it helped some but not enough to my satisfaction. I still have to check my ski alignment and I had installed a spacer on the back 1/2 of the rubber cushion for the ski mount that I will try removing. More to follow with more riding!!!
Ahem...Whitedust - you should trust the comment of a certain carbide manufacturer - he's pretty smart, as has been proven by setups on a couple of Yamaha's myself. He would have alot to lose if he couldn't prove some of those very critical comments. There is a reason people pay the big bucks for those triple points, shims and ski-savers.
700 miles on new skis 4 inch carbides, no darting, no push in corners, good bite in corners, may try 6 inch carbides one per ski, snow was mushey in western UP this past week, had slim jim duallys on yamaha skis- no darting but had a tendency to push in corners. I think this should be Yamaha's ski for all model's in the future IMHO.
Straightened out the ski alignment and rode some in the U.P. and around St. Germain last weekend. Seems like everything I do helps to reduce darting issue and is not effecting the supurb turning ability of these skis. I lengthened the limiter strap after I rode last weekend to see if helps the darting even more. I'll try that out in 2 weeks back in the U.P. All the adjustments that I made so far has also reduced the steering effort. More to follow in a couple of weeks.
Put them on 2011 Apex XTX and 2012 Vector LTX, 6/4 carbides on Apex and 4/2 on Vector, 3500 miles on Apex with this set UP, 1000 miles on Vector. All I can say is best money spent for handling/cornering. No darting, no push in corners[like slim jim's], ski lift only if you want it, and power steering is the CAT'S MEOW!
