Thanks for info. Tracker.
How many miles a dirt will she run in May?
Now that's a good one,Eh????????
As for the Sidewinder. There is quite a bit of talk of some owners blowing belts. I have been following the SW threads quite a bit on totallyamaha. First off it was thought the rollers were the culprit and maybe they are part of the equation. But what some are now discovering is there might be an issue with the secondary spring coil binding. Not all SW's are though, some have had zero belt issues. From what I am gathering is it's not really a design problem of the new roller clutch so much as a final quality issue. What some have seen is some casting slag left in the spring cavity which is not allowing the clutch to fully open at WOT. So the primary clutch is still closing trying to achieve top end but the secondary should be opening at the same time but stops doing so. This causes the belt to tighten up causing it to snap in half.
Don't shoot the messenger, just what I have been reading.
Those that have not had this issue seem to be happy with the performance. I have heard a few people needing to make suspension adjustments but that's not out of the norm. Not everyone rides the same or weighs the same.
ah yes....the low end clutch problem stated above....I know a fix for that too....that setup I said above aboot suspension....will APPLY to ALL weights and riders abilities....a light guy wont push....and a heavy guy wont push either...no matter what....its PHYSICS......not ABILITY.....its RATIOs.....not RIDERS.....and we don't wanna go there about .....HOW.....now do we.....98% of the people cannot understand why and theres been many threads aboot it...
PS....snowblower.....sleds are GLORIFIED ATVs with tracks....google sledding in sand dunes....and its all day....no over heat....no melting....but ya wont know this by sitting on the couch critiqueing people that have done it.....put down the BON BONS boys....emphasis on BOYS
Looks as if you called it right on snowbuilder!!!!! Eh??? snowblower???????? What's with that???
I would have to believe that Yam/Cat had access to every track available when they picked out the track for the 'Winder'/T-Cat. I would bet some attention was given to all conditions concerning forward traction, braking, cornering and top speed. They settled on a nice happy medium track which will suit most folks just fine. There will always be a better alternative depending on what the end consumer decides is the most important for the way they ride. At that point the end consumer can go ahead and put on whatever track he/she desires. If it were me I would put on an old conical lug track and stud the bejesus out of it. Just kidding. It was a very fast track though. Not good for much else.
