cuzzinolaf
Has anyone here replaced their 6203 OEM Arctic Cat bearing with something else? I pulled apart my diamond drive the other day and noticed the bearing seal on the one side came loose and the bearing started to break up. I have since purchased an SKF 5203 (changed to a 3203 recently) that is a little wider than the stock bearing. This is the same size bearing Black Diamond (Diamond Drive mfg.) sells to replace the bearing. Anyway, I'm reading things online where people with 2010 and 2011 M8s are machining down the track shaft or transfer gear shaft and I wanted to see if anyone has any experience with this at all.
