HardwaterHoosier
I'M running mine stock for the first tank of fuel.  Clutch and muffler swap after that.
			Loud cans spoil trails. I agree. They also loose performance so
anyone that knows anything won't run one. I did LOL at your comment about the "aim at the tree" lol...
Sure- I spent a couple years in the 2000's working with ISMA to establish the SAE testing procedures..Were you there? (In Coon Rapids, MN)
If you were involved you clearly understand the opposition to "cans"..even on RMKs...
	so you still got nothing to the question. ok got it. if you want to know on my m I run the speedwerx trail can with a,reducer in the inlet and my gade,is a stock can . i hope that is ok with you trail boss
It's time to just come out and say it > > > > Loud Cans Save's Lifes
so the trail boss disapproves . oh chit I best just quit snowmobiling now . anything else you disapprove of so I can fall in line with the great brads ideal of right and wrong ? still waiting on the tutorial from our resident sound engineer you have had plenty of time to google it and at least fake it
ZAC.....just an FYI...you need to break in a new sled with stock stuff...first....because the stock motor requires a SET PSI OF BACK PRESSURE to operate correctly...and the ECU is set for that...the reason a CAN SUKS and SUKS POWER is because it lowers the pressure....and guys like EZRA then add reducers to get it back down...but all this is retarted...since more power can be gained by smoothing out and enlarging the Y-PIPE just a skotch and using the stock pipe....restricting down to get required pressure and then into a wide open can....retarted at best...sell the can to someone on here....and rub one out on ye Y-PIPE....ye shall increase power....and loosening the limiter does not make you do wheelies either...that's retarted also....what it does it put more track on the ground and reduce air friction and drag at front of track and engagement with snow and gives more TORQUE and LOW END GRUNT and better STEERING....all these will make you shine...a CAN...not so much...along with some tickets for noise while going slower....LMAO
Bigfoot runs a loud can to scare people away.
what's a transfer block? sounds heavyo snap.....I thought he used DEER WHISTLES....learnt sumtin new ever day....LOL...plus I hear if you take out the transfer blocks you could wheelie right over the dude and stroke his hair with CAN WASH.....ROTFLMAO
Sorry- I forgot to provide you the test procedure: Attach the sound meter to a large tree, aim your sled directly at that tree and proceed at wide open throttle- Record max decibel level..
oh so clever even more funny when recycled . so still got notthing ha tester boy
the 8000 even with a y pipe makes more power with a rexucer . even with the stock sutecase you should use a reducer . just a fyi
i love the sound of a racing can at a gas station, waiting in line for their turn and not shutting off the machine! thats the best music eva!!!
oh! and then when they blip the throttle over and over to pull up when its their turn!!! thats so awesome too
