Got a question...
My AC is shot and it makes a good amount of noise. I saw a diagram that shows how the serpentine belt runs and 1 is with the AC and one is without. Could I get a new shorter belt and bypass the AC?
Looks like I can't. I'll be getting the A/C Compressor Bypass Pulley and a new serpentine belt. My belts a tad cracked/worn...
Got a question...
You may want to look at the belt tensioner. I will make noise only when the AC is on. You could try a shorter belt or a new tensioner. Sounds like a rattleing noise. I thought It was the AC compressor at 1st
Not to scare you of that truck but I have a 94, pretty much samething, interested difference is you have the vortec motor and 4L80E trans. But pay attention to the oil cooler lines, they will leak and are a pain to change. You can remove them completely and not worry. I took them off mine after I put a new motor in cuz mine took a main bearing and bearing material will not come out of the cooler completely. Another thing is water pumps, buddy of mine is on his 3rd pump and truck is just under 200k. Fuel pump will be another problem. If you do replace, go with the AC Delco brand. I put one in on mine from advanced auto and it lasted 6 months. Pay attention to radiator side tanks. They will leak. Intake gaskets as well. Another thing I do is when I change oil, is that I change the fuel filter. Yes it may seem crazy to do but it does extend the life of the pump. These are some things that I have ran into on mine and I've had mine for 10 yrs.
I like the way you think.
Indy check tensioner first. I've put 2 on my truck. My bad on the tranny. Thought after 96 is when they went to the 4L80E.
did or does the air work ?
About once a week I noticed a drop of coolant on the garage floor. My coolant level was going down VERY slow. Traced it to the intake gasket which is super common. Some was dripping down the side of the motor burning off. Some was getting in the engine (i saw rust on my plastic oil filler neck), and if I started my truck up on the driveway to move it into the garage, that's the only time I ever got it to drip. So what do I do? Go buy an intake gasket kit for $26.99. Start ripping it apart. I have everything pushed aside, labeled, etc. I just have the upper manifold, the intake, and the distributor left. I had a zip tie labeling every stinkin wire. I go to take off the heater hose fitting and it snaps. I worked on taking it out for 4 hours. I bought a larger extractor, applied TONS of heat, tried chiseling it out, and taking a hacksaw to it. No go. I bought the new heater fitting also, which is steel unlike the old one. I finally give up and my dad says lets take it somewhere.![]()
