I'm now $100 into the thing. Probably $20 in gas making 5 trips to fleet, and 2 to menards so far! I just ordered $26 worth of parts today such as the driveshaft triangular flange (the square hole for the carriage bolts stripped out), carb gasket and float bowl gasket, chaincase seal, gas tank fitting that broke off, and the O-rings behind the chaincase bearings. And, to top it off, $13 shipping! yahoo! I got both footwells done, but I feel like I sort of slacked on them. I ran out of rivets, and just used bolts to finish up the right side. My rivet gun started acting up, and half of the rivets i put in were leaving the metal rod thing in there and I had to snip them off. I also made running board supports (the running boards were WEAK!). The engine is all painted up, clutch cleaned, chaincase was cleaned and installed, I installed the fuel pump rebuild kit and cleaned it up, and put new fuel line on. Just waiting on the gas tank fitting for that. The engine was ready to go in tonight, but me and acatzl550 decided to go cause some trouble instead. Ski's and suspension will get disassembled and ready for paint tomorrow, and motor installed. 2 motor mounts were shot. I was able to save one, and used a spare I had for the other one. Parts I still want are a new rubber track and windshield.
