I agree on coolest looking engines, had a TX500 (or atleast I believe it was a TX) 3 cylinder free air, heads sat out of the hood, from recoil to clutch was as wide as the chassis was which made it very tippy, and I would keep blowing the exhaust joint apart. I don't remember the year of it either, was one of my first sleds when I was young.A lot of guys are still out there throwing a line in the water but the soft water fishing is over for me so it’s time to start dealing with the multi-page list of projects that need to get done on the home front.
It may not be the best idea but my plan is to do some time-slicing on activities so I can fit in some work on the mutt. I took advantage of the unusually nice October weather yesterday to do what I hope is the last of the outdoor blasting.
Part of the engine detailing was to get it bead blasted. This was my first attempt at glass bead blasting and I guess it came out OK. I probably could have spent a little more time prepping the engine before blasting it because the beads aren’t terribly abrasive but it should be fine for my purposes. I will replace the carb boots and probably the seals before it is eventually fired up. I know I’m biased but I think these 70’s free air motors are some of the coolest looking engines ever put in a sled.
Speaking of blasting, my inexpensive Harbor Freight hopper system that I use outdoors is not as aggressive as the big commercial units but sometimes that isn't a bad thing. It works well enough to remove the scale and it should only take a light sanding to get the parts ready for painting. This shot gives you some idea of what the bigger parts look like before and after blasting.
My first sled was a 72' bolens sprint which had an all-rubber track and a morphadyted slide rail suspension that ran in a track meant for boogie wheels, used to carry a bottle of dish soap for lubricant LOL, anyways... my second sled was a Polaris Elektra cleated track and I remember quite fondly the days of grinding cleat rivets, was always a joy LOL. Was a good sled, trunk under seat gave me years of enjoyment as a young kid, those were the days I could ride right out of my parents back yard and most of my friends in the neighborhood had sleds also. ahhhhh those were the good ole days, then it really didn't matter what you had for a sled, as long as you had one.Happy Halloween! Seemed like the perfect occasion to grab a power tool so I spent a few hours today grinding, and drilling rivets to remove the 20 broken track cleats. Now I just need to remove 20 good cleats from a donor track, get them cleaned/painted and installed. Sounds easy but it’s a pretty big job. Will post an update on the track once it's finished.
