Thanks, hoping the project will live up to expectations.
It took a few sessions to get every nook and cranny blasted but it was mostly done in this shot. One of the obvious issues with the all steel chassis is rust-through, especially if it has been sitting out in the weeds for a couple of decades. This one was pretty good with only some minor rust in the reinforcing plate at the end of the tunnel, which could be easily repaired with metal filler.
If anyone has the impression that I have some kind of high dollar shop operation, this should cure that impression. I use this inexpensive hopper setup from Harbor Freight for all of my outside, big part blasting. It’s not as fast as a big commercial setup but it’s also not as harsh. I have pushed a lot of blasting material through this thing and have (literally) blown through a couple of steel nozzles. Luckily, for as crude as the gun is, the nozzles are replaceable and I discovered that common steel spacer/sleeve stock fits perfectly and is readily available at most hardware stores.
