Thanks guys!
I am feeling somewhat better, at least for a few hours of each day.  Other times during the day, not so much.  Had the COVID (rapid) test, came back negative but I don’t know, this seems different than anything I’ve had in the past.  Been monitoring my O[SUB]2[/SUB] level and so far, it’s holding at the low end of the normal range so I guess that’s good.
I know I probably talk too much about the little things on a project, but sometimes these little things can really throw a wrench into project progress if you can’t come up with a solution to a problem.
The bushings on the ski shocks were badly deteriorated and at some point, a previous owner decided to try to preserve them by dousing them with epoxy.  All this succeeded in doing is fusing the bushings to the sleeves.  I had to drill a series of holes in each bushing to weaken this bond so the sleeves could be pressed out.
Obviously, the factory bushings have been long out of production so the search for a suitable replacement was on.  Summit Racing had the answer - sets of two-part bushings that were almost exactly what I was looking for.  The ID and length were perfect but the OD of the insert section was just a hair too big.  Some careful grinding on the bench grinder to reduce the OD and they fit nice and snug.
