misty_pines
The Dark Side
Now that I have joined the Dark Side, I feel qualified to answer this question
I would recommend running your current oil down fairly low before adding the Citgo just to be safe. Most oils are compatible so you probably won't have any problems mixing them, but by running down low, there will be less mixing if that makes any sense.
Can you mix citgo oil with other or should you empty oil out of tank ? I have a skidoo and it is on a half , will it hurt to top it off with citgo oil now ? Can someone let me know.
