OK so I picked up the truck after having the A.R.E. topper, Bed Rug, and Swing Case installed. I love the Bed Rug and Swing Case The A.R.E is a nice fit, but the paint match to the new 2013 Tuxedo Black is kind of, well I don't know. If you are right up close they appear to be a good match. Then when you see it at different angles, the topper looks like it does not have as much metallic as the truck. Love the fit, it has no wind noise and helps with Fuel Economy at least I think. Truck was getting 17.5 before the topper, and yesterday drove 200 miles, and had 18.6 Mpg when I got home. I don't know how much was still getting better from break in as I only have 1200 miles so far.
Over all I am happy with the topper, I like that I can keep my large tool carrier in the box. I could not do that with the
Tonneau covers. I really like the remote lock option of the Z series. Only Con: As I said depending on what angle you look the paint may not be exact match.
I do not have the need to haul anything large in this truck, so limited height will not be a problem.They would not be removable it you had to you could but the wiring ext would be enough just to use your trailer to haul the big stuff.
Good luck with what ever choice you make. Undercover is good and a lot less expensive. My total cost was just under 3K for topper with power lock, front tilt sliding window, power lock, swing case, and bed rug.
