I was just going to ask the same LOL don't remember finger throttles back in the day LOL. SOUNDS GOOD skiroule!!! that sound brings back many memories! and again...a true master at your craft!!Nice! Real Nice! Please forgive me, but, I do have a dumb question, why is the throttle a pull lever vs. a push lever? Was that typical in the day? Nonetheless, awsome....
seal up the intake and exhaust and do a pressure testI'm no mechanic, but, I think you have answered your own question. If one cylinder is happy with the tuned pipe, the other should be as well. Is there any way to test that theory before you pull the motor?
I don’t know about answering my own questions but I often argue with myself and still manage to lose the argument. I’ve been eyeballing it and I might be able to pull everything with the motor still in the chassis. If not, removing the motor is about a one-hour job. Would suck to have to re-align everything though.I'm no mechanic, but, I think you have answered your own question. If one cylinder is happy with the tuned pipe, the other should be as well. Is there any way to test that theory before you pull the motor?
This is really the right way to diagnose the condition of the seals without tearing down the engine. The trick is getting a perfect seal on the intake and exhaust ports so the leak-down test is accurate. Even a tiny leak in the test setup will give a false result. Not having a setup already, I’m not real confident I could build something that I could guarantee is accurate.seal up the intake and exhaust and do a pressure test
Now that is sound advice. No harm, no foul.One easy way to determine seal leak is with starting fluid, carb clean or wd 40, spray it around seal while running and see if the idle changes or not. I highly doubt it would be the tuned pipe. Im sure you have checked the obvious as well...intake leak...properly adjusted choke. In my experience a seal leak will affect more than just up to 3000 rpm's which leads me to think the issue may lie in the carburetor itself, namely the pilot circuit which will considerably affect the idle and up to that rpm range. are both carburetors jetted the same? I only ask because some engines have a richer jet on the PTO side. if jetted the same try switching the carburetors and see if the problem follows by disconnecting one plug wire at a time and see which cylinder is affected. I could be wrong but doubt it is a crank seal or a tuned pipe issue as I dont think either one would only affect that idle and rpm range. Those carbs looked like you could drink from them but its what you cant see that causes issues. If you can I would first try swapping carbs and see if problem follows, I may be wrong but I'm betting on fuel delivery. in my experience the seal that would only affect the idle zone of the machine and would not only affect one side was a center crank seal
Good to get some input from someone who knows small engines. I agree that a seal or the pipe just doesn’t make sense, especially since these engines are not prone to seal failure, center or otherwise but at this point I’m still in the dark.One easy way to determine seal leak is with starting fluid, carb clean or wd 40, spray it around seal while running and see if the idle changes or not. I highly doubt it would be the tuned pipe. Im sure you have checked the obvious as well...intake leak...properly adjusted choke. In my experience a seal leak will affect more than just up to 3000 rpm's which leads me to think the issue may lie in the carburetor itself, namely the pilot circuit which will considerably affect the idle and up to that rpm range. are both carburetors jetted the same? I only ask because some engines have a richer jet on the PTO side. if jetted the same try switching the carburetors and see if the problem follows by disconnecting one plug wire at a time and see which cylinder is affected. I could be wrong but doubt it is a crank seal or a tuned pipe issue as I dont think either one would only affect that idle and rpm range. Those carbs looked like you could drink from them but its what you cant see that causes issues. If you can I would first try swapping carbs and see if problem follows, I may be wrong but I'm betting on fuel delivery. in my experience the seal that would only affect the idle zone of the machine and would not only affect one side was a center crank seal
does the engine have a starter cup on it that you can wrap a rope around and start the engine with the recoil removed? if so, start the engine that way and spray along side flywheel if there is a seal leak where it is drawing air you should know instantly, without having to pressure test the engine. I would still try swapping the pto side carb with mag just to eliminate the carburetor possibility even though they are new. I still highly doubt the pipe possibility especially since its isolated to one cylinder. Do you possibly have an inductive or in line spark tester where you can see the pulse of the light to compare to other side to see any difference or interruption in ignition in case it is an ignition issue?Good to get some input from someone who knows small engines. I agree that a seal or the pipe just doesn’t make sense, especially since these engines are not prone to seal failure, center or otherwise but at this point I’m still in the dark.
Here’s where I’m at so far. When I first got it running, I had installed a new set of carb boots but a set of used carbs. It was obvious that it was only firing on one cylinder so I assumed a carb problem. I ordered a set of new VM34’s, figuring I could go through the first set eventually and use them on another sled.
When I started it with the new carbs, at first it seemed a little better but eventually I concluded that it was basically the same. I had swapped out the mains to 310’s but kept the 30 pilots that came with the new carbs. As much as I’d like it to be a carb problem, it now seems unlikely. The choke thing is something to be checked out though, as I used the same set of plungers on both carb sets.
After running, the mag side cylinder is noticeably cooler, which seems consistent with it sounding like it is running on one cylinder a lot of the time.
It’s hard to spray anything on the mag side seal because of the rewind cover and flywheel but tomorrow night I’m going to start by swapping the carbs. If nothing changes, I’ll swap plugs and then plug wires. I do have another CDI box but it seems like they should either work on not. If all these things have no effect, I’ll pull the pipe. If I’m still where I started, I probably have no choice but to check the seal.
I did have a Fuji engine on a Chaparral that ran poorly and would not idle and the problem turned out to be a mag side seal. The tension spring had broken and dislodged from the seal so it was sucking major air though the seal. The Polaris version of th Fuji uses an entirely different seal design so it would suprise me if it was a major seal failure but I guess you never can say for sure.
Thanks again for the advice!
