It’s hard to believe how many things can go wrong with a motor and yet they run most of the time. I did check the compression on both cylinders after I first got it running – 135 in both cylinders. Not great, but not bad for a 45 year-old motor. Also took a peek at the pistons back when I had the Y-pipe and carb boots off. Thought the pistons looked pretty good.
First thing I did tonight was to check something I thought I’d seen with the first set of carbs and wanted make sure it wasn’t my imagination.
I started it and held the idle just low enough to keep it running on one cylinder. Then I gave the mag side carb a couple of shots of gas. Bam - that cylinder started firing and the RPMs jumped by a couple of thousand. So it wasn’t my imagination. Next thing was to swap the carbs and run the test again. Same result, only started firing on the mag side at idle when I gave it a shot of gas.
I guess what this tells me is that I can rule out some kind of ignition problem and it suggests that there is a fuel/air ratio issue that is not providing the proper ratio to fire the cylinder at idle. After seeing the same result with three different carbs, it’s probably safe to say it’s not the carb. It could still be a boot issue but the boots are new so that’s a long shot.
I should have tried to run it without the pipe but after removing the pipe I figured I might as well tear into the seal because I wanted to change it anyway. Even for a hack mechanic, it’s less than an hour job to get it out. I love the seal design of these Fuji engines. The mag and pto sides are slightly different but the concept is similar. Rather than drive the seal into the case, the seal is mounted in a plate which is fastened to the case with four bolts/screws.
This is what it looks like on the mag side before removal and after replacement.
I was hoping the seal would look visibly bad but it didn’t have any obvious flaws, no tears or chunks missing. It seemed a little spongy but maybe that’s wishful thinking.
Anyway, the seal is in and stator plate re-mounted.
I put the flywheel back on but don’t have the right size socket to snug down the flywheel bolt (I cheated on the socket taking it off but didn’t want to torque it down without the right one).
We’ll see if it makes a difference tomorrow night but I have this uneasy feeling Euphoric1, that you’ve been right all along, it really wasn’t the seal after all.
Thanks for letting me think out loud about this!
