I can't believe how much difference it looks with just a few parts installed for "morale " purposes!I received an awesome, American-made carb adaptor boot from Rick down at Rick’s Rupps here in MN, which allowed me to mount a Mikuni VM36 carb instead of the original diaphragm version. The adaptor for the Sachs manifold has to have 3” bolt centers, which makes them a little harder to come by but he had one.
Since jetting is a crapshoot at this point, I decided to stay with the jetting (35 pilot, 310 main) that came with the carb and tweak it as needed, assuming it runs at all. It might not actually be that far off for my purposes.
Hooked a new throttle cable up to the carb and the throttle block on the bars. I couldn’t believe how well it fit the throttle block, considering the block wasn’t designed for the Mikuni cable. Drilled the block out just a hair so the cable still fit tight, pressed the cable in, and tightened the set screw – done. Couldn’t resist squeezing the throttle 5 or 6 times (OK, 10 or 20).
Also, test-fit some other handlebar stuff (mostly for morale purposes). Once I’m satisfied that everything is ready, I’ll fasten things down for good and put the handlebar grips on.
Actually, I WAS DROPPED ON MY HEAD as a small child. And as long as we're sitting around the wood stove drinking beer, here's the story. I had tonsillitis at an early age, while being placed under with anethesia, I managed to crawl or fall off the table landing on my head. This being prior to the age of litigation, the Doctors simply put me back on the table and went to work with knife & saw. Went home the next day with a sore head and sore throat. I think they felt bad though, afterwards they gave me all the ice cream I could eat.Kirk, the belt change is super-easy, no tools or foul language required.
mike1970 and euphoric1, I did manage to make some smoke in the shop today. Started the RTX for the first time with a tank fuel supply. Fired right up but it’s not quite time to break out the good beer.
It won’t idle below about 4500 RPMs, which would indicate that it’s pulling air from somewhere. I’d always been a little suspicious of the fact that there were Permatex remnants along the crankcase seam, like someone had tried to seal it. Question is, did they take it apart to do this or just try a superficial application because they knew they had a problem?
Tore down my “practice motor” and found out there is NO gasket between the case halves so the motor shouldn’t need much in the way of help to get a good seal. Looks like there’s a good chance it’s crank seals on the sled motor.
So….the bottom end will have to come apart. It will set the project back some and there’s probably no pony in the poop pile but there are some positives: It runs, the top end didn’t grenade so that looks OK, the clutch looks like it works as intended, and the running gear got a good run-out.
Once I get to it, the repair isn’t an insurmountable task, should be able to get it done this month if I can score some shop time. I already pulled the clutch – (one of biggest problems with crank seal replacement on these old motors).
This all begs the question, why didn’t I tear down the bottom end in the first place? I’m told that I was dropped on my head as a very small child but I doubt there’s any connection.
Yes, I agree that this is a good starting point. In this case, the idle screw had virtually no effect. In fact, full choke wouldn't kill the engine - had to put my hand over the carb to kill it (no wiring yet to kill the ignition). There's a major air leak somewhere.I always turn the idle screws down as far as I can on Mikuni round slide carburetors. This allows the pilot system to operate correctly and doesn't create a opportunity for the main circuit to supply fuel.
Yamabond, 518 flange sealer or if you know a Stihl dealer near you Dirko sealant is another good crankcase sealer. has to be a good feeling knowing it runs! too bad there wasn't smellovision on this site, can see the hue of two stroke in your pic now only need the smell...love it!!
I've used Permatex 51813 for many years with zero issues. Yamabond is also highly regarded. Either way what you need is a good anaerobic sealant for your crankcase. Never, never, never use an RTV type sealer on crankcase halves.
The seepage thing on the seal may have happened but I’m thinking it shouldn’t have. It seems like the seal should have been good enough to keep the oil in the engine.At least you should keep some refreshments close by, alcohol is a good cleaning solution!! It removes any fingerprints.
If oil was poured into the engine, and said oil level was above the seal (or any hole where fasteners attach), it could have seeped through to the area you mentioned. Unless you find another scenario that makes logical sense, I am guessing that is what happened.
I do not have one. I should put together some kind of leak-down test kit for checking these old cases. I guess the trick is to get it built and installed correctly so I have confidence in it not producing false leak readings. It’s a long shot but I’ll do some checking around town and see what I can find.skiroule, do you have a pressure/vac tester? those older engines are not difficult to block off intake and exhaust ports and put some pressure and pull some vac and check the integrity of the crankcase seal and crank seals before you just drop it back in the chassis and assume the air leak has been stopped. I have no doubt you will have taken care of leak but just to cross your t's and dot your i's since you are at this point due to a known air leak.
Since I always appreciate a mildly warped sense of humor, this gave me a good laugh.skiroule (Kelly?): FWIW, way, way back,when I first saw just the title of this thread last year I thought you were going to be writing about a new made-in-Japan sled,
The "Namesake" (Na me sa ke): ナメサケ(Katakana) なめさけ(Hiragana). or 鮭 (Kanji) = "Salmon"!(?)
Fortunately this thread turned out to be far more interesting than that would have been!![]()
Now that would be cool retrofitted with an 800cc engine. Does anyone out there actually have one of these? no wonder why Honda never ventured into the snowmobile industry...What were they thinking?
