L
lenny
So Lenny do you think the whole viewing is north of Paulding and does not include Paulding itself? I would not be completely suprised... I just wanted to make the fact earlier that US45 DOES come into alignment with the old US45 in Paulding. And as you stated it's also in alignment north of the curve north of Sleepy Hollow Road (and past Bruce Crossings for about 6 miles for that matter). Like someone stated earlier with the different headlights nowadays it's not suprising to just see white but white'ish colors also. Thanks for the update!![]()
Yes, I would bet some serious cash the lights are north of paulding. as I said before, while viewing the lights coming down the gradual grade, you can see flatter areas in the roads and than a slight dip, a 25 second duration of constant direct view and than a slow veer to the right. With that in mind, as i drove back I looked for that topography and was somewhat certain I found it. Nash is 100% correct, The Tunland Lake rd is the precise spot, at least for sure in the sweet spot. I should have taken notes as my memory is fading somewhat, because of time (age?)
