Good looking sled Indy! Before you head north spend a bit more cash on some No Snows or Better Boards! Snow pack on the tunnel is miserable!
He's got one of my dimple dies. Indy you can do every dimple on that sled but one, check for support bracket under neath board. you can also add a dimple farther up in foot well. That will take care of your snow. Takes about an hr. per side.
how big of holes does it make, I cut my boards out on my old mtn lite and installed better boards and it finally was the fix, holes still clog IMO
I can't see how those dimples will do a darn thing when carving and snatching loads of snow,,,,, better boards all the way Wayne
You don't need to Lenny. our job is to ride and not worry so much! The boards are fine on my 2012 Pro. but to spend the big bucks to improve the boards on an old edge chassis with better boards??? That is just bad money management.
I ordered a set of B&M tube type for My M
the 11 M had big cut outs still worthless.
I would pay for a guy to build a set of tube style with a coolant hook up on both ends would really only need to heat tube along tunnel to do its job. or whole board and could prob scrap rear cooler then weight would be close to a wash then.
B&M did A group buy on snowest $320 a set. I played on there demos at haydays I think they are going to hold up well.
was thinking only thing besides turning them to a cooler would be flat stack along tunnel instead of tubing. the tubining is just going to be 1 more place to collect ice.
I am sure I will still need to lug around rubber hammer during some conditions.
I might get the B@M fab ones for my pro, mine are bending already.![]()
So much for slowing down as you get older! Way to go Skylar!
Here is a good Poo story! 2011 with about 2G still pounding it out on the originals...
http://www.youtube.com/watch?v=YuiSyyTF_LE
I like Indy's $5 and problem gone. Keep in mind a 2010 is an old sled by my standards.now now Wayne, if you ride a sled off trail and the boards are loaded up all the time than a fix is worth it. $200 and problem gone, worth it!
Lenny, you can not dimple die Skylars sled. he has a Pro, his boards are way different then tool was ment for.come on Skylar, just buy a pimple die kit and drill holes. You can wipe your boots back and forth all day like a dog with a itchy butt. Why just let the snow fall through when you can stomp it through all day...lol
Skylar your the 2nd guy I heard who wants to beef up his boards and let more snow thru on "our" model of sled. Keep us informed if you change your boards please. (I am not jumping higher either, but sure packing on the weight). So far boards still look great. Also does cutting up boards and installing aftermarket boards affect resale value?
not speaking for Skylar but the mod would be for pure functionality out of necessity. Guys like us need the sled to perform and that is first and foremost priority, resale is in the back of our minds
